Obviously buying as you need them is one way to go. But you have to wait and shipping would likely make this cost prohibitive. If you had an opportunity get cobalt and carbide end mills to get started , what would want knowing what you know now? These will be used on aluminum and mild steel initially. Will be used a 3 hp 9x49 machine.
There are so many options for roughing coarse and fine, corner radii, center cutting, high helix, variable flute, 2/3/4/5 flutes, coatings....Oh.....
Thanks for the help.
