Maybe this will help someone. I had tools and parts that were rusty so I bought a vibratory tumbler from Harbor Freight for $55. They have a larger one for about $100 more but I modified the small one and it works great. All it is basically is an a.c. motor that the shaft has a weight attached offset so it vibrates. Motor is spring and bolt mounted to a plate which has a drum. Problem is nothing very large fits in it. I replaced the holding drum with a 15"x6"x9" Sterilite box (Walmart $2.97) that has a locking lid. I used original hardware then put a piece of cardboard in bottom to cover screws. I put the abrasive, shells or resin pellets in a large plastic pickle jar. Now the rusty tools and parts in jar, lid screwed on and there's no dust. As it runs the jar slowly turns! It works so great just thought I'd mention it. You could probably even use a larger box within reason, make sure it's mounted evenly for balance.
Sent from my SM-S320VL using Tapatalk
