Okay guys, I'm stumped here. I single point threaded a shaft to fit a "nut" with a known size and thread pitch (I made it, and used a drill and tap to create the internal threads). I first turned the shaft down to the specified OD, then set up the gears on my lathe for the correct thread pitch. I threaded in reverse using an internal threading tool on the back side. I got good looking threads, cleaned them up and tried to thread the two parts together.... only got a thread or two, so I took another pass of a few thou. After that, I could only get 3-4 threads. I continued to cut deeper and deeper unto I could get 10-12 threads, but then the first several threads were very loose, then it got tight and stopped before I reached the bottom of either of my threads. It's as if the threads were cut on a taper, like pipe threads, only a very small one. What am I doing wrong?
For reference, I can thread the tap back into my female part by hand, so I'm pretty sure toffee threads are right, it's just that my male threads start lose and get tight.
Sent from my SAMSUNG-SM-G891A using Tapatalk
