'K, we were at cross purposes.... no issue, talking "past each other".
What's wrong with my threading technique?
Last edited by J Tiers; 04-29-2018, 11:48 PM.CNC machines only go through the motions.
Originally posted by txfireguy2003 View PostOkay, so I went back and started over with standard threading technique and have been able to make several threads that accept commercial nuts with a very good fit. The only issue now is terrible surface finish, especially in steels. These were done with carbide inserts, and I'd read that HSS gives a better finish than carbide at low speeds, and that it's tougher, as in it doesn't chip as bad (which I haven't had problems with). So tonight, I tried a HSS threading insert from AR Warner, and it left terrible surface finish too, and the tip broke on a pass with 0.005" in feed on the compound (set to 29 degrees). It broke mid pass on a 1/2-28 thread in what I think is 4140. I know 4140 isn't the easiest steel to machine, but it's a fairly common steel for rifle barrels, which is my ultimate goal. In fact, this was a junk rifle barrel I was practicing on. I guess I'll stick to the carbide inserts, but I sure wish I could get a better finish.
Sent from my SAMSUNG-SM-G891A using Tapatalk'It may not always be the best policy to do what is best technically, but those responsible for policy can never form a right judgement without knowledge of what is right technically' - 'Dutch' Kindelberger
Originally posted by Richard P Wilson View PostI'm surprised you managed to chip an HSS tool, they are pretty resistant to that sort of thing. 0.005" isn't an excessive cut in the early stages of a 1/2" x28 thread, though you'd want to be down to 1 or 2 thou and spring cuts towards the end.Try grinding a single point tool from a decent quality HSS blank. It isn't difficult to grind a 60 degree point using a thread gauge, and you are going to have to learn how to grind your own tools sooner or later anyway. Flood with decent cutting oil, feed in on an angle if you must, personally for a thread that small, I'd just plunge cut it. Check the basics - is the work well supported, is the tool set on centre height? What speed are you using?
Two possible issues, but I dont really think so: this insert and holder came with the lathe, I bought it used from the original owner's family, he died 13 years ago and it still had the rifle barrel he was working on chucked in it, so everything than came with it is at least that old.... but I'm not seeing how the insert could go bad, it seemed sharp. The only other thing I can come up with is geometry as the holder holds the tool in a negative position, but it seems like that would make the tool less likely to snap, but maybe I'm wrong there.
Originally posted by txfireguy2003 View Post... The "chips" that came off on the first two passes were not even really chips, more like metal dust suspended in the cutting oil. On the third pass, I was getting the same thing for about half the pass, then it snapped off. ...Location: Long Island, N.Y.
If you are too high, the tool "rubs" and does not cut well. But with a negative rake, that may not be so true... w negative rake, when high, will act much more like a neutral rake, which it actually will BE at a particular height.
I have no experience with the Warner HSS. No idea if it has a sharp tip, or a flatted tip for the stand up (the lay down seems to have a radius). I have knocked the tips of plenty of HSS tools until I decided to put a flat on them. A sharp end on the tool will be easy to break, and also heats up fast, potentially getting dull and then breaking off due to the forces of trying to push a dull tool through tough material.
Also, 4140 and HSS is not a great combo, although in my experience it takes a while to wear down the HSS to where it does not do a good job. Especially if you are not getting blue or brown chips.
A negative rake... that might have an influence, since it effectively makes the cutter act duller. Are you sure that is the correct holder for the threading insert? Never mind what the previous owner did..... Check and make sure.
The cutter might have to be ground specially for a negative rake, because the angle changes the cut angle so that the actual cut is not the same as the angle of the ground tip.
I looked in the catalog (last one 2014) at http://www.arwarnerco.com/catalog%202014.pdf and they have both stand-up and lay-down insert holders. Could not make sense of the codes, even looking at the catalog explanation, at least not as regards threading and the angle the insert is held at.
So, while the report you give of negative rake seems unlikely, and the geometry of the inserts seems wrong for that, I can't prove it.Last edited by J Tiers; 04-30-2018, 02:01 AM.CNC machines only go through the motions.
If its just coming off as dust, theres something wrong with the tool, its either blunt, too high or the helix angle is wrong, and its rubbing, not cutting. Grind an HSS blank, put some top rake on it, a little helix angle and try again. For small threads like yours, I use a 1/4" dia HSS toolbit clamped in a 3/4" square MS holder, so twisting round to get the helix angle is easy.'It may not always be the best policy to do what is best technically, but those responsible for policy can never form a right judgement without knowledge of what is right technically' - 'Dutch' Kindelberger
Originally posted by txfireguy2003 View PostI was turning 60RPM
Cutting your relief groove at the shoulder before threading helps, then you can be mentally prepared to drop the half nut lever as soon as the threading tip enters the relief groove. There's nothing wrong with making the groove a little wider if you want some extra margin for error.
Okay, here are some pics from this afternoon:This is the tool I was trying to use.
Here's a barrel stub cut down to just shy of .500" (.490 by my micrometer, not sure what's up with my DRO, was shooting for .495").
A scratch pass with 28tpi thread gauge showing correct machine settings.
Ready to go with oil on it.
1/2 way through first cutting pass, with .005" in feed on the compound, cross slide set back to zero, the to breaks off the insert.
A pic of the broken tip.
So I swapped back to the carbide, picked up the original thread path, and finished up. It's a little loser than I'd like, but it locks up tight to the shoulder and turns true. I'm thinking if I had hit the .495 major diameter from the start, it would have been a better fit.
Well, there's your problem. That is the wrong holder for that insert. The top surface of the insert is sloping down at what I would guess is 30 degrees. It should be horizontal. The edge that touches first is the cutting edge and it MUST be right at the centerline to get the best results.
When you have that much rake you are not cutting as much as you are plowing your way into the metal. I suspect that the carbide insert is working because it's in a different holder.
I'm often amazed by how much "machining" you can do with the machine set up all wrong.
DanAt the end of the project, there is a profound difference between spare parts and left over parts.
Originally posted by danlb View PostWell, there's your problem. That is the wrong holder for that insert. The top surface of the insert is sloping down at what I would guess is 30 degrees. It should be horizontal. The edge that touches first is the cutting edge and it MUST be right at the centerline to get the best results.
DanLocation: Helsinki, Finland, Europe
