Jerry, I wasn't guessing; I gave an example that I have personal experience with. That's why I said "for example". It certainly could be a very minor difference in pitch, nobody knows. You're theory though is based on an assumption that both threads are of correct pitch diameter - but if you continue to feed the tool in further to cut a deeper thread, as the OP said he did, the wrong pitch will thread on farther and farther. That's what I experienced, and that's what the OP described. The actual values are not as important as the concept, and who knows if the OP actually meant a specific number of threads literally, or just as an example.
I said "once again" because you have a consistent habit of insisting your theories about what "should" be are more valid than someone else's actual experience. It detracts from the overall value of the forum.
David Powell, obviously we are trying to help the fellow, and what you suggested is pretty well covered under the previous suggestions that there is a pitch diameter mismatch. Any of those are possible, up to the OP to figure out what since there's no way for us to know for sure.
