Bearing and seal catalog online?
  • Bearing and seal catalog online?
    Who sells bearings and seals online organized by id od etc instead of part number?
    Most seal part numbers are the size.
    ex> A 20mm bore by 45mm od x 7mm thick seal would have a part# 20-45-7 DL or SL
    DL= double lip SL= Single lip
    Bearings see below link:
    http://www.ntnamerica.com/tech_support.htm
    Any good bearing/seal shop should be able to help you when you have the measurements.
    eddie
    please visit my webpage:
    http://motorworks88.webs.com/
