I want to build a piece from two 6061 plates. Held apart by a spacer with a step on the end going into reamed hole in the 6061, then held with washer and bolt.
Originally this spacer was to be stainless, but I am now thinking 7075 instead.
I am thinking this should not cause seizing problems. The pieces won't be twisting against each other, once in place , but might be occasionally removed or changed to different lengths.
So my question I , will they stick or gall ?
