I will try and get some pictures up later but for now I built a homemade brake that goes into the hydraulic press. Looks similar to all the other ones on google images, top die is a piece 1”x5” crs with a 45 degree angle cut on each side to make 90. Bottom die is just a piece of angle stood up and cradled in between 2 other pieces of angle. Width of brake is 6”.
Trying to bend 1/4” cold rolled steel 4” wide, the back of the material stress cracks. Cracks start to form around 30 degrees of bend. Top die opening is 2 1/4” wide. Top die was initially a sharp point but has since been blunted and slight radius with no change.
1/8” material bent without any issues. Any ideas on what move to make next?
