Okay, I've got this uber-cheap Chinese CNC engraver/mill thing. The spindle is probably running 1000-2000 rpm (since I blew the 24vdc supply and am running a 20vdc laptop supply until my real solution arrives). It's mounted on rubber feet, inside a fiber-board and plex enclosure, sitting on an inch of Styrofoam, and then on 1/4" of rubberish yoga mat (found on the side of the road... I don't do yoga, just wanted to be clear), and then on a wooden cabinet, on a concrete floor. When it's running, I can feel the vibration tickling my feet in the next room, 20 feet away. Said problem might go away when I get more voltage and up the spindle rpm, or it might not. Might get worse.
It doesn't make much noise, especially with the case lid on. Just purrs along, but it buzzes the floor... in a condo. Not good.
Putting aside the notion that I'm going to in some way magically fix the rig so that it's in balance and doesn't buzz, any ideas on what I can do to isolate it?
Right now, it's metal, rubber, foam, rubber, wood, concrete... and it's buzzing the concrete. This thing is tiny... I could put it on a concrete patio block, on the foam, on the rubber, on the... Do you think that would help? Anything else? Layers of wood and rubber? What?
Mass or squishy, or both? Something else? Anyone ever successfully isolated this kind of vibration?
David...
David...
