Originally posted by lakeside53
View Post
Recommendations for an Ultrasonic Cleaner
Originally posted by BCRider View PostAnd before anyone mentions Simple Green as a good solvent for items just a reminder that it eats into steel. It's a fairly slow meal but over time or enough repeated uses it will haze the surface of steel. And with enough single immersion time it'll pit the surface. I ruined a perfectly good bicycle chain one time when I forgot to remove it from some SG for a few days. When it said "deep cleaning" I didn't expect it to be THAT deep....
I found it to be much better than water for cleaning stuff, but I usually need the part right away so get them out of the tub before a half hour has passed.
Use the minimum amount of liquid your cleaner can handle, especially if you've got an underpowered one.
Originally posted by Jon Heron View Post
Similarly sized 3 liter model ~80 usd from germany or 10 liter/ 2.5 gallon US cleaner is about 140 usd .Last edited by MattiJ; 04-01-2018, 03:51 AM.Location: Helsinki, Finland, Europe
I fixed two ultrasonic cleaners for my dentist. The problem is quite evident, a couple blown diodes and a high voltage MOSFET:
A good view of the guts:
He also gave me a larger, older one, that I cleaned up but have not yet fixed:
He also gave me a smaller one that he bought at Target. I used it once, and it seemed OK. Also found at Home Depot:
https://www.homedepot.com/p/SPT-Ultr...0609/202498189http://pauleschoen.com/pix/PM08_P76_P54.png
USA Maryland 21030
