I'm going to build a slitting saw arbor for a 3-3/8" slitting saw (re-purposed carbide tipped trim saw blade). The arbor will extend from spindle nose by about 1.5-2". Is 3/4" sufficient or should I take the time to make it R8? I've seen nice DIY designs of both....
slitting saw arbor build - R8 or 3/4" straight shank
For out to about 1.5" extension you'd be fine. If you want to run it further out than that by something like 2 to 2.5" extension then I'd do something similar to the Tormac style stub arbor where there's a shoulder that runs up against the spindle nose for a larger "footprint". Tightening the collet then draws the shoulder up against the nose of the spindle with some good force for more stability. For much over 2.5" of extension I'd want to go with a large full length one piece option with the R8 shankChilliwack BC, Canada
Originally posted by Tim Clarke View PostGiven the nature of saws to cut on just a few teeth, I'd assume that adding the runout of a collet would be best avoided. Mine are somewhat less than perfect. Checked my 3/4" and it's got about .0004" as close as I can tell.Chilliwack BC, Canada
Thanks for all the input, you've convinced me 3/4" is fine, I may design it to pull up against the spindle nose as an option. Norman your design was one that I found on a google images search that I was fond of. With regard to runout I've read the same, that it's the saw that is usually the worst offender. I planned to check my blade once mounted up and massage it as necessary.
I think if I needed to make another, that I would do it as a weldment. That is, rather than start with, something like 35mm round stock, and carve the shaft from that, I would select a shaft from suitable cold rolled stock and, after drilling a hole all the way thru the end portion, weld it to the end portion.
Weld would only be at the intersection of the shaft and the end portion. True up the end portion to the shaft after welding. The female threaded (nut) portion for the cap screw would still be into the shaft.
If one used the weldment approach, the shaft could be left "sticking out" of the chuck by an inch or so in order to true it up with a dial indicator prior to cutting the end.Last edited by Norman Bain; 04-05-2018, 04:26 PM.
Originally posted by Tim Clarke View PostGiven the nature of saws to cut on just a few teeth, I'd assume that adding the runout of a collet would be best avoided. Mine are somewhat less than perfect. Checked my 3/4" and it's got about .0004" as close as I can tell.CNC machines only go through the motions
Originally posted by J Tiers View PostThere is the fit of the saw on the arbor, which is usually a straight-sided fit, for which you can expect a minimum of a thou possible runout. Don;t sweat the runout issue.... runout will be there regardless.I cut it off twice; it's still too short
Oregon, USA
