I have a flat little 3" sine bar that is about 3/16" thick. It has a step in one end. I use it in the mill once in a while, and also use it to set something a precise angle off of the back rail on a surface grinder. I made mine, although I think you can buy them reasonably. I made a set of standards for all of the usual angles, and also have a set of gauge blocks for the ones I don't have.
Thinking I need some angle blocks
Bingo Tomato!
Congratulations! It's a fun little exercise.
And, by the way, cubes grow much faster than squares. For example, if you wanted to resolve all angles from 0.5 degrees to 60.5 degrees every half degree, you could do it with only 5 blocks:
0.5, 1.5, 4.5, 13.5, and 40.5.
Thanks for the few than sent an answer. Happy weekend to all.
Half a degree is a pretty coarse resolution, no good at all if you want to make Morse tapers, tapered gibs and the like. Sine bars and slips (gauge blocks) are the way to go.
For home shop use there are plenty of cheap second hand sine bars on eBay and a box of old slip gauges will do fine. The slip gauges at the museum had to have the rust scraped off them, but even so, a stack of four still reads within about 3 microns of their marked values.
Originally posted by dryfarmer View PostI dont understand the puzzle how do you get even a 2 or a 5
EDIT - You guys are too quick for me. Going back to my corner.
