A bit of jewellry making tackle, a ring facetting machine. And then what happens?
  • A bit of jewellry making tackle, a ring facetting machine. And then what happens?
    And now for something completely different....
    I acquired this recently with some other items, its used in faceting rings and such. There is no brand mentioned on it but after an huge amount of googling I've identified it as part of a FMTD diamond facet cutter. Swiss, for cutting diamonds in metal, not for cutting diamonds. A jewelers tool. I believe the idea is a with a super sharp tool, a brilliant reflective surface is left.
    Cleaned up well and all the parts are there. Not sure what I'll do with it other than let it hold a bench down......anyone ever used one? have a brilliant ideas? It could easily be mounted on a mill, but cries out for some sort of rapid advancement with a stop
    You are in luck, a guy just posted looking for something to set up angles..
      I think the more important question is ... how exactly do you come across this stuff? LOL!
      If I had no use for that thing I would put it on my desk. I know they say beauty is the the eye of the beholder, but folks can keep their fancy paintings on the walls. I'd like my house littered with mechanisms like this one.
      Sorry I can't help you as to how you would use it. But nice job on the cleanup.
      www.thecogwheel.net
        Isn't that the gadget Apollo Nine used to get back to earth?
          lol, right place right time. Keep in mind, the posts of the fun stuff don't share the burden of the wasted trips. If there is any secret, its the same as every good salespersons knows; ask the extra questions.
            Originally posted by Mcgyver View Post
            ... If there is any secret, its the same as every good salespersons knows; ask the extra questions.
            Yep. Asked if the guy had a jeweler's lathe when I bought my Glendo Accu-finish from him. So he pulls out a Boley, with a toolbox full of stuff (tools, watch and clock parts, etc), and about 50 WW collets.... price $25, including a base and motor. He wasn't selling any cross-slides, though, so all it has is a graver rest.
              Maybe you could mod it to hold and sharpen bits or lathe tools.
                its a good idea...but I built one eons ago to do just that . I'm going to have to start wearing rings
                  Damn, that is NICE!
                    Faceting RINGS? Or is it for faceting gems to put on rings? Could do either one.
                      faceting rings. To make it more confusing its often called diamond faceting, but they mean it makes diamond shaped facets not that its faceting diamonds. I've come across faceting machines for diamonds for small dollars (relatively), but was never tempted as that truly seemed something i could never conjure a use for.
                        What a beauty, it would be a shame to expose it to abrasive dust particles. Micro milling tiny model parts would be it's forte, with a collet fitted to the arm, perhaps.
                          Turn it into a Goniometer!
                          Here is one I found many years ago - modified it into a small grinder for profiling etc.
                          Geoff
