I need to pump water from a stream to a pond. The lift is about 12 feet. I saw a credible youtube video of a Rule 4000 bilge pump supplied with 400 watts of solar panels. He's using no controller to prevent low voltage to the pump. Have a hunch they are operating manually, switch on when the sun shines. I can find a million controllers that charge batteries and have a low voltage cutoff but I don't want/need batteries. I'm needing a relay or equal that closes when the solar panel output is adequate to run the pump and opens when it drops below a certain level. Perhaps 28V on, 22 V off. Is there a name for such a device that I can search for?
I'm sure a simple circuit would do it but it seems my electronic designs usually end up with problems that I can't solve.
