Originally posted by garyhlucas
View Post
Solar Pumping
Originally posted by GKman View PostThanks Mike,
Believe it or not I have two pumping right now. They are powered by a 7' head through 1" galvanized steel pipes where the stream is dammed. They have to lift that 7' plus the 12' talked about above. When the drive pipes have just been cleaned and a syphon is working over the dam they each pump a gallon/minute. Doesn't sound like much, but they never rest 24 7 except for winter weather when freezing could damage them. That's over 300,000 gal/yr. Have photos and video if anyone is interested, I'll try to post some. For those not familiar with them they use the energy of about 7 gallons of water going through them 1 where I want it and 6 on down stream where it was going anyway.
I'm glad that "hydraulic ram pump" is known by somebody other than me. About 50 years ago I worked for a company where a previous owner would come around to get something made or repaired (we built machinery). He owned property that had a stream and he really liked hydraulic ram pumps. He would buy one and bring it in our shop for us to take apart, clean up, repair if necessary, paint it, and put it on a pallet for him to pick up. These pumps were by no means any sort of "red neck" contraption. They were manufactured by people who knew a lot about it. The pumps he brought in looked like they were made of cast iron. For sure castings.....maybe steel. They also had some sort of pressure domes on them. He had at least two operating 24/7 when freezing was not likely (we are in Michigan....it freezes). The pumps provided water for some beautiful ponds that he had made. When he died, the estate he left to a local college was worth about $11 million. Not hardly redneck.
im very pleased with the way my solar porch turned out - on a 35 degree day it can get up to 90 on the porch, while the porch is heating up the solar panel is pumping it's energy into the duct work by means of an old gutted out double insulated computer power box that has two little 65watt a piece halogen headlight bulbs with a computer heat sink machined out to fit them - a 12 volt computer fan that blows the pre-heated air from the box and into the duct work, it's all thermally protected with a high temp cut out but never has yet kicked off AFAIK -
@ 75 degree porch temp the power gets disconnected from the pre-heat and goes directly to the main fans - before there was a cold blast of air for quite awhile but the pre-heater does a fair job at at least keeping things neutral for starters,
back of the house was always cold - not any more, it's set it and forget it, does not matter if power goes out the system works flawlessly - and when it's raining the people knocking at the front door have a place to stand without getting wet thanks again to the panel... also creates a no slip area in the winter right where it's needed most at the step... solar can be fun too, how one old 170 watt panel can make such a difference when used correctly is very cool - literally as i can use same system in the summer to suck the hottest air off the porch peak and pump it directly into the attic - it's cold air compared to attic temps so gives the roofing shingles a break and helps keep the entire house a little cooler too....Last edited by A.K. Boomer; 04-10-2018, 04:32 PM.
https://youtu.be/46Sf2snNvJo
Ram Pump working. Danger may cause excitement overload. Check with your doctor first
