I posted earlier some questions about a heavier duty machine than what I had. I have purchased a Rockwell (no mention of Delta with it) that doesn't have everything but it is bigger, beefier & a floor model. I can find no reference to it afaik on the net. It has no model #, simply a catalog # (4-15-214) & a Serial (G4587).
As supplied it has a 1/2 Hp, 1725 rpm, 208 volt, 3 phase motor that I will replace or... (can't imagine much use for a 3 phase this small). There are 6 speeds using a pair of 6 speed cone pulleys. Unlike the current fashion of an intermediate pulley mounted in the top of the column this one only has a motor/spindle pair. Based on motor rpm & pulley sizes it should have spindle speeds of (rounded off): 400, 600, 1100, 2000, 3800, 5500. It has close to 6 inches of quill extension and 15 inch capacity. Quill extension is a 3-position handle.
The table has 4 slots arranged at 45 degrees to the column. It is adjustable to vertical (parallel to the quill) but it does not rotate about a central pivot.
Jacobs 1/2 inch geared chuck. I'll have to do some cleaning to read any info. Immediately above the chuck - see http://vintagemachinery.org/pubs/1141/1701.pdf. About half way is a series of 3 drawings labeled "Extra Large Spindle Bearings" - is a bushing with 3 holes spaced like those on a Drill chuck for the key wrench and above one of them either a small hex screw or a roll pin (full of gunk).
My questions:
1. Any insight into researching a catalog number (not a model number?) for a "pure" (I think) Rockwell machine to help hunt down a manual?
2. How do I remove the chuck? I removed the inspection plate in front of the quill (where a switch for a single phase motor would be expected) and tried to locate an opening for a drift to drive out what I thought would be the morse taper spindle inserted into the quill - no go. This arrangement - whatever it is - is new to me. Or, is it not involved at all?
My questions:
