I have a Er32 lathe chuck and I'm pretty much sold on using collets in the lathe but I need something larger, I have been looking but I have found very little past ER40, anyone have any idea as to where I might find a lathe collet chuck that is at least ER50(34mm)???
Lathe collet chuck with a miniumum 30mm(ER50? but 40mm would be ideal) capacity??
Just make one. You can get replacement nuts and wrenches from the usual suppliers. You've got a lathe. What more do you need?.
Originally posted by Mark Rand View PostYou could look at 16C collets. They go up to 41mm, although the adjustment range is smaller than ER colletc, so you need more of them for a given range.
Yep. This is another reason C series collets for work holding are a better choice than ER for work holding. A 5C would work easily if you can use a pot collet.If you think you understand what is going on, you haven't been paying attention.
Originally posted by dalee100 View PostHi,
Yep. This is another reason C series collets for work holding are a better choice than ER for work holding. A 5C would work easily if you can use a pot collet.If you benefit from the Dunning-Kruger Effect you may not even know it ;-)
Originally posted by Magicniner View PostThe reason C series collets have smaller range steps is that they are single taper and after a very small adjustment only close further at the front, this makes them worse than ER unless the C series is very close to the size of the work.
What makes ER less desirable for work holding is the lack of versatility. Fine if all you want to do is small round stuff held by the OD. But show me the square or hex ER collets? The pot or clutch collets? Emergency collets? None of those are available for ER collets.
There would be a lot of things I make that would be impossible to do if I had to use ER collets.If you think you understand what is going on, you haven't been paying attention.
There would be a lot of things I make that would be impossible to do if I had to use ER collets.in Toronto Ontario - where are you?
ER is nice if the engagement length is longer or at least nearly as long as the collet. But they won't hold short parts. That's where 5C or similar one ended collets come in. Otherwise you'd need to pack the far end of an ER collet with a spacer that is the same size as the part you want to hold. And that would be a PITA in short order.
This need to fill or nearly fill the length of the collet so the ER can seat correctly is going to be worse as the size of the collet increases. And I see from a quick search that an ER50 collet is 2.36 inches long.
With this in mind I can't see it taking the place of a regular scroll chuck for my needs.Chilliwack BC, Canada
In addition to round stock up to 30mm OD (My Myford Super 7 only has 30.5mm through capacity), I also machine octagonal, hex and square in ER40 on the lathe without issues, here's a "Cookie Cutter" I made today from hex brass bar for quickly and neatly removing pan lubed Martini Henry 45-70 heads from the set lube, I make them in stainless too
The end of the 1m length of stock sticking out the back of the head stock had a tiny bit of run out at the end but not enough to require using the stabilising support.
HTHIf you benefit from the Dunning-Kruger Effect you may not even know it ;-)
Square or hex parts isn't a huge issue for me as I don't do a lot of that on the lathe(not any so far) and a morse taper pot-chuck or a shoulder bored split ring will take care of what little need I have for short parts(suppressor baffles), my only use for a large collet chuck will be round-stock and it will be as much raw stock with good surface finish(no mill-scale/hot-rolled) as it will be round pieces that have already been turned.
All of this is why I would prefer a ER50 over something else, 16c looks interesting but the prices are less so(if one can even find a page with the price listed...) and I do need at least a range of collets from 20mm and up so price wise ER seems to be the only option, so far it looks like I will either have to make an ER50 chuck or buy an ER40(which short-term, is the most likely option unless I find a ready-made ER50).
Give the relative low price and the versatility for home shop use even on smaller lathes it is strange(annoying) that ER50 chucks aren't more prevalent and available...
Originally posted by MasterMaker View PostGive the relative low price and the versatility for home shop use even on smaller lathes it is strange(annoying) that ER50 chucks aren't more prevalent and available...
