Originally posted by vpt
View Post
Heaviest thing you loaded on a trailer with a Cherry picker.
Originally posted by dave_r View PostNo, you build a flat platform for the end of the lift, then you can put the ladder on that. You can get an extra 10+ feet higher for free!
Just 2 weeks ago a Parker Majestic No 2 surface grinder wandered into my garage. I rented the cutest little Uhaul trailer. It was extremely useful for it’s size! I was able to lift the grinder with my engine hoist.
The lift moved the grinder ok. The grinder is nearly as heavy as my Bridgeport!
I think around 2000 lbs. The grinder comes in at 1500 lbs and the trailer had no problem with it. We loaded it so the weight was over the axle. I used a punch bar to walk it back so I could hoist it up and drive out. The deck of the trailer is corrugated sheet metal. The trailer is stout for it’s size.
I do not need another trailer as my open car hauler works well for most things including hauling my Camaro but if I were in the market for a 4’ x 7’ I would look for a used Uhaul trailer. Very well built. Real nice feature is it’s low ride height. Makes for easier unloading with a engine hoist.
