Fordillac V-8 engine running, finally
  • #16
    Have to agree with everyone else- that is a fine piece of craftsmanship. Sounds cool too!
    • #17
      What can you say ... sounds so good almost want to make it my ringtone. lol.
      I notice that you do have a starter motor on it, Is it an off shelf item and will it actually start the engine. It looks
      perfect, and was just wondering.
      John Titor, when are you.
      • #18
        George mentions in the video that all of the bolt on components like starter, generator, and fuel pump are non functional but are scale replicas added to enhance the realism of the engine.
        You can also see him use a hand held drill inserted into the bellhousing in order to start the engine.
        • #19
          Thanks Willy ..
          I actually watched the vid, but the list of accomplishments was so long that it must have gotten lost in my brain.
          And I don't know if it would be cheating, but couldn't you put a very powerful off shelf motor inside a replicate casing
          of the starter motor .. and have it actually start the motor. Just think that would add coolness to it.
          • #20
            A friend has an engine with a starter motor. It's out of scale but works fine. A high rpm motor from an RC car can be used but would need to be geared down considerably to get enough torque to start the engine. The dummy starter on this engine is just way too small to retrofit anything comparable.
            There are some model engines mounted on a box with the starter underneath. A toothed belt transmits rotation to a one-way bearing, which I also use. I have what looks like a clutch assembly bolted to the flywheel and in the clutch is my one-way bearing.
            gbritnell
            • #21
              well .. i can only glimpse into your league. I don't have enough life left to get that good ... lol
              Anyways ... thanks for sharing.
