3 phase questions
  • #16
    +1 for the VFD idea. They're cheap, and incredibly useful. You have variable speed at your fingertips without changing belts. And the 3-phase motor will run more smoothly and quietly than the single phase.
    I replaced the single phase motor on my mill/drill with a 3-phase and a 1-to-3 phase VFD, and am absolutely delighted with the result. In fact I will probably do the same for the lathe in the not too distant future.
    • #17
      Three phase motors are incredibly tolerant of abuse. Even more so if simply kept from overheating. Kept an entire chemical plant running on single phase by watering a couple of overheating motors. Bagging machines drive a screw auger and instantly reverse by throwing them in reverse while running full speed. Car wash dryer blower was intentionally overloaded by 50% because it only operated about 5 seconds out of each minute.
      • #18
        "I replaced the single phase motor on my mill/drill with a 3-phase and a 1-to-3 phase VFD, and am absolutely delighted with the result."
        Me too! A mill Drill and a Grizzly G4002 lathe and then I also converted 4 drill presses to 3 phase & VFD. The ONLY way to go. Instant speed control and reverse at your fingertips.
        CPeter
        Grantham, New Hampshire
