Let say you have drill and counter sink 5 holes using a milling machine(non-production scenerio). Do you first drill all the holes and then change the tool to counter sink, or do you drill and counter sink each hole at a time. Because I don't have a DRO, I find that I do the latter so that I don't lose the position. It does mean that I have to change the tool 10 times but it's better than having a counter sink which isn't concentric. Is this the approach that most HSM use?
This may sound like a silly question, but when you don't have any formal training in the field and you're tinkering all by yourself in the garage, you start to wonder whether something you're doing is completely out of wack.
Albert
Albert
