Not sure if the photo will take. Cant make sense of this plate, I want 110 cw rotation, its a used motor of a door opener and there are a few more wires then whats shown on the plate. Putting it on a wood lathe.
Cant make sense of this plate, I want 110 cw rotation, Putting it on a wood lathe.
Connect black and blue to L-1
Connect red and white to L-2
Put wire nuts on all the remaining wires so they don't make contact with each other or anything else.
How often does a lathe run each year? The have doors/gates that open/shut 30-50 time and hour all day. That's far harder than continuous run, and a lathe is rarey at full load for long periods.
