I have an older Makita 10" wood-cutting chop saw that I have tried metal cutting with an abrasive cut-off blade. It works, but leaves a mess of fine abrasive and cuts slow. Is there a faster cutting blade that will work with that saw, maybe a diamond blade? I am cutting angle iron and steel tubing, not metal sheet.
Makita 10: wood type chop saw - is there a metal-cutting diamond blade that will work
Nope... std size. I use one all the time, but with a super thin 10 inch abrasive.
Diamond? not for cutting steel.
Also.. it's much too fast for steel cutting carbide blades, and you'd need a good way to clamp down the material. They are scary enough on aluminum.Last edited by lakeside53; 05-01-2018, 08:21 PM.
Sounds like it's time for a 4x6 bandsaw! I thought I didn't need one till I had to get one for a particular job with a ton of stainless cutoffs, now I couldn't live without it. At Harbor Freight it'll set you back $208 (with a 20% coupon as usual). Mine is a similar cheap import, lots of the members have these I believe.
I've also heard that the abrasive dust will kill tools not designed for it. Common problem using tools on materials they're not designed for. I once killed a Porter-Cable router using it on aluminum when a piece of swarf went inside and shorted it.Location: Jersey City NJ USA
Originally posted by gellfex View PostSounds like it's time for a 4x6 bandsaw! I thought I didn't need one till I had to get one for a particular job with a ton of stainless cutoffs, now I couldn't live without it. At Harbor Freight it'll set you back $208 (with a 20% coupon as usual). Mine is a similar cheap import, lots of the members have these I believe.
I would not bother with this hobby if I had to cut metal by hand. I have an abrasive metal chop saw that hasent been used for months and all of my hack saw blades are new.
BilliI cut it off twice and it's still too short!
Thanks for the thoughts and replies guys. I have a Harbor Freight 4 x 6 metal cutting bandsaw which does a nice job except for the blade coming loose a little too often. I am just trying to get some use from this old Makita saw since I recently acquired a Dewalt 12" sliding miter saw. I think I will look into that diamond saw suggested by garyhlucas.
Originally posted by Planeman41 View PostThanks for the thoughts and replies guys. I have a Harbor Freight 4 x 6 metal cutting bandsaw which does a nice job except for the blade coming loose a little too often. I am just trying to get some use from this old Makita saw since I recently acquired a Dewalt 12" sliding miter saw. I think I will look into that diamond saw suggested by garyhlucas.Chilliwack BC, Canada
Wood saws go fast. That works for wood.
Metal saws go slow. That works for metal.
That is the most basic difference between wood and metal saws. The differences in the blade design is of lesser import.
Will a metal saw/blade cut wood? Yes. But not well.
Will a wood saw/blade cut metal? Yes. But, again, not well.
Why fight it?
If you really want to cut metal with a WOOD saw, use an abrasive blade. Diamond will work, but diamond is CARBON and the high speed and the heat generated will literally burn the diamond away so this will prove to be expensive. Diamond blades should be either run slow or with coolant to keep them cool. I would use a different abrasive: any hardware store has abrasive disks made for chop saws. Yea, abrasive dust all over the place. Been there! Done That! And there is no tee shirt for it. My METAL CUTTING band saw (4x6) is the second most used machine in my shop: the drill press is probably the most used as just about everything needs holes.
PS: Both types will cut your finger off. The wood saw will do it faster so less pain.Paul A.
Paul,
The diamond cutting wheels I used on a 4-1/2" grinder cutting both stainless welds and tubing cost $14 at Home Depot, 3 different brands. It outlasted the thin abrasive wheels at least 10 to 1! It stayed the same diameter the whole time so no trying to cut with a tiny worn down wheel, and the blade speed stayed high. There was no abrasive dust, only metal and very little smell. When the blade would no longer cut because the diamonds were worn away from the outside rim the diamonds on the side were still good for flat grinding. They say you can cool with water for even longer life but I was working on a job where that wasn't practical. I needed to fishmouth a 2" tube on a 4" diameter and roughed it out on the bandsaw. Then used a 4" diamond blade on an arbor and fed it sideways through the tubing in the mill. Did two of them and they came out really nice because the diameter hardly changed.
It's a new world concerning diamonds. I was at a trade show where a company was showing amorphous diamond thrust bearings in downhole drills at extreme pressures and temperatures. I can get pump seals with diamond coated faces for really abrasive material pumping.
It's a new world concerning diamonds. I was at a trade show where a company was showing amorphous diamond thrust bearings in downhole drills at extreme pressures and temperatures. I can get pump seals with diamond coated faces for really abrasive material pumping.Location: Helsinki, Finland, Europe
Originally posted by dian View Postinteresting. what wheels are they? i see only this in that price range:
https://www.homedepot.com/p/Rubi-4-1...1914/301239300Now cut metal like never before Introducing the new RIDGID Diamond Cut Blade, with up to 70x more life. Now a single blade can outlast as many as 70 abrasive discs, giving you the lowest cost per cut.
Diablo's new diamond metal cut-off wheels deliver extreme durability, minimal downtime and increased productivity. These diamond rimmed wheels deliver 100X longer cutting life versus a standard bonded
Quite mixed reviews so I'm interested to know what garyhlucas was using.Location: Helsinki, Finland, Europe
