Enco Model 205-6215 Power Feed
  • Enco Model 205-6215 Power Feed
    About 6 months ago I purchased a used Bridgeport that has an Enco model 205-6215, 135 power feed on the X axis. I just got the mill to my home shop and am ready to get it working. Unfortunately, some wise guy cut both the cords off the power feed, possibly by the riggers when the mill was moved from it's former home. I'm reasonably sure one cord is the power and the other went to the limit switch. Do any of you by chance have a wiring diagram for this thing or know where I might find one? This unit was made in Taiwan so odds are good they were also sold with other brands on them. It's also possible the unit is bad and rather that take the time to fix or replace it, the operator cut the cords off and continued to use the X axis in manual feed. A wiring diagram would be most helpful to troubleshoot this thing. Next option is to pull it off, throw it on the bench and see if I can figure it out.
    Thanks in advance for your help,
    Bob
    Never looked closely at mine. I would assume the power cord has three conductors.
    The limit switch is simple and would only need two wires.
    Lesson from the wise: once it is working, do not shift directions without letting the motor stop.
    The plastic gear that gets stripped is up around thirty bucks now.
      The power cord ought to be straightforward. For 110VAC, I expect you will see three conductors with insulation as follows: green (ground pin), black (copper screw in plug/narrow blade) and white (silver screw in plug/wide blade).
      Here from my comfy chair, I don't immediately have a suggestion for the limit switch. Can check a similar feed later if someone else doesn't provide a definitive answer in the meantime. How many wires do you see for the limit?
        Both cords are 3 conductor.
          Any chance of there being three wires for the limit switch: red, blue & black ?
            One has a larger black sheath and the three conductors within are heavier gauge w/ green, black & white insulation, yes?
              There's a good chance that Enco power feeds are made by Align--I know they make others.
              Here's a link to an Align manual in PDF--bet there's little difference if any...
              http://www.elrodmachine.com/PDF/ALig...n%20Manual.pdf
              Keith
              __________________________
                That certainly looks very similar. I'll do a little more investigating tomorrow.
                Thanks,
                Bob
                  Pulled the power feed from the Bridgeport and disassembled it far enough to do some testing. While I was getting continuity through the on/off switch and the circuit breaker, I wasn't getting power out of the circuit board to the motor. While pondering that, it dawned on me the gear was missing from the driven shaft. I think it's time to look for a new power feed. Any suggestions for a decent one that won't break the bank?
                    Got my Align power feed from Bestline Products in Garden Grove CA. They claim to have lots of parts so may be able to help. I have the manual for mine so could scan and send the circuit diagram it that would help. The limit switch is actually two micro switches so the three wires. There are no color codes that I can see on the wiring diagram and being Chinese made they don't necessarily use the same colors we do in North America.
                    Larry
                      ASONG also makes power feeds for other manufacturers. It wouldn't surprise me if ASONG made Align feeds. Align is in a lot of different markets and the power feed is just one of them. I don't think they make anything themselves. All the major brands use the same parts with a few variations for the power series. (Motor armature, etc.) I bought the ASONG for my knee lift after some investigating and because it was a complete kit. When the old 50-pound Bridgeport X-feed goes out (gears are almost gone), I'll be getting another ASONG.
                        Larry, I appreciate the offer of scanning your manual, but I think I'll scrap this one out in light of the missing gear and it's overall condition. I'm afraid I would put way more time and money into this one than what it's worth. You're right about the color coding, both cords are black, white and green. Go figure.
                        Thanks again,
                        Bob
                          Thanks Ken, I'll look into the ASONG power feeds.
                          Bob
                            I asked earlier whether the insulation on the three conductors for the limit switch were red, blue and black.
                            I understand that you have decided to move on from trying to restore the existing unit. Still, I'm interested in knowing whether the effort I put into finding information for you led to a correct answer ...
                            Edit: Please disregard. I just noticed your earlier post indicating both cords have the same colours.
                            Thanks for the acknowledgement
                              No problem Eddy and thanks for your help!
                              Bob
