Do screwdrivers come shaped like forks?
  • Do screwdrivers come shaped like forks?
    I have an adjustment nut on the sears table saw fence that is in a recess. It has two screwdriver slots on the face of the nut opposing each other with the bolt passing through them.
    Sort of like trying to turn a crown nut from the end with two screwdrivers.
    I have tried two screwdrivers, one in each slot but too much flex and the nut is rusted.
    Do they make such a tool or do I have to build one?
    I could use a pipe and mill the end to leave two blades and heat treat.
    One more project that I don't have time for.
    There is such a thing, I know exactly what you are talking about. I've seen and used them but can't for the life of me remember the name!
    Like this, right:
    https://www.dearbornclassics.com/win...1961-1964.html
      Use a Dremel type cutoff wheel to cut a slot in the middle, use an impact screw driver, and replace it with a normal screw.
        I came across one of these may years ago. I modified a standard screwdriver blade by filing a slot into it, leaving 2 prongs like Dracula's teeth. Screwdriver blades seem to be tough, but fileable, at least the one I chose was.
        'It may not always be the best policy to do what is best technically, but those responsible for policy can never form a right judgement without knowledge of what is right technically' - 'Dutch' Kindelberger
          I've only seen those tools shaped like a pipe with horns on the end.
          I've made several but have never hardened one in order to use it. They were generally single use tools.
          Dan
            Your a Home Shop Machinist, I bet you can figure it out. Making a new tool is part of the fun, Post a photo of your results.
            Oregon Coast
              If its two pins, they come in security driver sets. I have a couple around the shop. If its two blades as I got the impression I have never seen one.
                blades not pins
                Alanganes hit on the head.
                Now to find the right sized one.
                  I made a similar tool from a socket wrench. I milled it with carbide and it was tough to cut. I should have roughed out the shape with a cutoff wheel in a grinder. It would have saved a lot of time at the mill.
                    The more I think on it, I think I will sacrifice a nut driver.
                    Mill the business end to the right shape.
                    I may need the depth as the male thread may protrude too far for a modified screwdriver.
                    Yes a deep socket will do the trick.
                    One more custom tool to put in the custom tool drawer that will never be used again.
                      Bezel Nut Wrench
                      A search brings up variations. Here is one style:
                      https://www.npdlink.com/store/produc...868-51195.html
                      And another
                      http://dennis-carpenter.com/dash-bez...tool/p/TL-200/
                        Ya mean like this one ???
                        I had to make this one to remove the screws on the bottom of a drip coffee maker.
                        JL...............
                          If its the style of nut that Alan linked to, then the wrench is a common photographer's tool. Google "lens spanner wrench". You'll see dozens of varieties.
                          Kevin
                          More tools than sense.
                            I would just get a garden weeding tool and mod it.
                              JL...............
                              I bought a big cheap ($5) screwdriver to modify exactly like that to fit the nuts that secures the hand wheels to the shafts on my 9" SB lathe's cross slide and compound slide. Easy peasy.
