Life's been a bit bumpy the past few years but I am very slowly piecing together the shop I've always wanted. I've got a detached, insulated 1120 square foot building with 3 roll up doors that is dedicated to shop space. Right now, it has 30 amp service - obviously nowhere near enough!
I basically have two options where the first option is the "best" but is going to be expensive and probably take me a much longer time with all the other projects I have going on (this house was a major fixer-upper). The second option is not quite as good but is much easier to implement. Conventional wisdom says to oversize everything and grow into it but I'm worried that I may end up waiting another several years before I'm able to do that...
1) Replace 200 amp service with 325/400 service - Based on conversation with poco, it looks like they would keep the drop the same size but I would have to hire an electrician to install a new meter pan with dual lugs. Then I would run one branch to the 200 amp panel in the house and the second branch (4/0-4/0-4/0-2) would run to a 200 amp panel in the shop. This is both expensive and would have to be scheduled sometime in the indefinite future. The main complication here is the state of the house wiring. I'm slowly bringing it up to code. Each time I rennovate a section of the house, I run new electrical, all to code, to a new 200 amp panel that is being fed as a sub. Eventually, I'll have the poco pull the meter and I'll move the SE cable over to the new 200 amp panel and remove all the old stuff. But until I'm ready to move the SE cable, I don't really want to involve an electrician (FWIW, I am allowed to do my own electrical work past the meter as long as I get it inspected) only because I'm concerned about the project scope exploding.
2) Run 150 amp sub-panel in shop - This is the easiest solution because I can pick away at it myself and at my own pace and then have it inspected when complete. It's also much cheaper. Basically, I'd be popping in a 150 amp breaker in the 200 amp house panel and running 2/0-2/0-1-4 to the shop. The material is cheaper, no need to hire anyone, schedule flexibility, etc. But now I've got 200 amps for both the house and shop. I don't want to blow the main breaker if my furnace kicks on or my dryer is running and I try to start an arc with my welder! And, of course, I have 150 amps instead of 200 in the shop.
The equipment I want to run in the shop:
Lights
General purpose 20 amp outlets
Window AC
Furnace
Syncrowave 350
Phase converter (10 hp idler motor)
Bridgeport (3/4 hp 3-ph motor)
KT 2D (3/4 hp 3-ph motor)
Cincinnati horizontal mill (2 hp? 3-ph motor)
Bandsaw (1 hp 3-ph motor)
Pacemaker #1 (5 hp 3-ph motor)
Pacemaker #2 (7.5 hp 3-ph motor)
Drill press (1.5 hp 3-ph motor)
Shaper (5 hp 3-ph motor)
Etc.
Of course, this is a one man shop and it's unlikely I'll ever have my Syncrowave cranked up to its max setting. The most I can see myself doing is letting the bandsaw or shaper run while I'm also doing some TIG welding or machining on another machine. Most of the machines are less than 2 hp, with the exception of the lathes. But there again, it's unlikely I'll be hogging off enough to hit the FLA since I'm doing this mostly as a hobby now. Also, if I'm in the shop, the house is empty so it's not like there's a huge power draw there. No central AC, either.
I just can't decide what to do. I hate to hobble myself with an undersized electrical system but I also don't want to wait forever... It's already been 3 years since I moved in and I haven't even started on the shop!
Lights
Window AC
Furnace
Syncrowave 350
Etc.
