Originally posted by DrMike
View Post
You hear more lows and highs as the sound level increases, so the A weighted curve does not fit all situations. But it is so widely used that you more or less have to use it too.
I think you need to do several days, because the use of A/C will vary also. You want to find the worst days, not the quietest days. A loud noise that hardly ever happens is often counted less than a somewhat quieter noise that is present more of the time. And a constant noise is more impressive.
Be prepared for the county to discount everything. Had a problem with a landlord not turning on the heat. Had the city guy come out. My thermometer was on the table, reading 60F. The city guy pulls a fairly heavy metal-cased dial thermometer (that would be used to measure liquid temps) out of his inside pocket (under his jacket), and lays it on the table next to mine.
A minute or two later he picks it up, notes that it reads 80F, and says "I see no problem here, your thermometer is wrong.".
Obviously he did not want to find a problem, and very likely your guy will not want to either.
