Hardness of needle
  • Hardness of needle
    A friend wanted to know what the hardness of a sewing machine needle is. First of all, are they made of hardened stainless steel? What would it be on HRC scale?
    Also, how would you measure hardness on a sample that small?
    [This message has been edited by rotate (edited 09-01-2004).]
    Usually high carbon steel wire, chrome and sometimes platinum plated.
      I've used them for screwdriver blades.(small blades, as in watch size)
        With the ends ground off square and set into a 3/8 cold rolled handle the machine needles make excellent miniature pin punches.
        I'm thinking the harness must be around 55-58c,any hrder and they would break like glass.
          PSD Ken, thanks for the tip on using needles for small screwdrivers.
          THAT OLD GANG 'O MINE
