Big hydrauliclly powered syringe
  • tlfamm
    I'm sure my family doctor had one that size when I was a kid and had to go for "a shot".---Brian
    Reminds me of my childhood doctor: big needles, sharpened at least once a year. Who could imagine one-time use micro-fine hypodermic needles?
  • boslab
    Thinking about it Milwaukee do a mastic gun that size, 18v, very good, hell of a squeeze, I used one with sausage packs fitting windows, I’m using a pump one now, not as elegant, are you going to make water wings for sheep?, or inflatable saddles.
    ( the local sex shop sells inflatable sheep, they don’t do refunds though, the shop opposite sells wellingtons too,)
    Next will be RF welding vinyl I’m sure
    Regards
    Mark
  • old mart
    Ahh, The Black Forest Colonic Irrigation Service is in town.
  • RichR
    Just what are you planning on doing to those poor sheep now?
  • boslab
    That’s not a syringe that’s a mini extrusion press, change the needle for a die,
    Mark
  • brian Rupnow
  • Black Forest
    started a topic Big hydrauliclly powered syringe
    Today I started building a big syringe. The syringe is 300mm long and 52mm inside diameter. I will use a hydraulic cylinder to push the piston in the syringe. All the components are pretty much finished. Now I need to build the frame and the check valve that I will put in the piston face so I can withdraw the piston/plunger without sucking back the paste I am injecting. When I get it working I will post pictures and a video.
