Three Jaw chuck jaws another idea
  • Three Jaw chuck jaws another idea
    I have seen quite a few ideas for re-grinding chuck jaws, (and I collect them!) now here is another couple of ideas for internal and external re grinding.
    Just when you think every possible method has been tried, along comes a couple more...
    http://www.homemetalshopclub.org/news/aug04/aug04.html
    BTW, if you look under the latest newsletter (september) there is an article on balancing grinding wheels.
    Peter, Thanks for the link. It looks like you might want to watch rpms with those springy blocks in place though. I'm thinking that you might be able to mill a simple spider shape from a solid plate to emulate what he's got there, without the danger.
    Den
      Den,
      He did say to run it as slow as possible.
      IMHO, a bit much work to avoid drilling holes in your jaws. I just drilled and cut a ring from a piece of pipe. Much easier and the holes hurt nothing. Probably a retired guy with one of those perfect lawns and a perfectly painted and clean house. Not a leaf in sight in the yard.
      Make it fit.
