Things are changing fast these days and I'm having trouble keeping up with the new stuff.
Allan Ostling's post on a new catalyst for hydrogen generation comes to mind, but there are others.
One I read about yesterday is "plastic wood." No, not your stupid-heavy lump of melted plastic, but very, very wood-like structures. Basically, they take the resin and solvents, mix in some water, and put it in a mould. Then, they freeze the bottom of it in a very controlled way. Ice crystals form that mimic the structure of wood, then they cure the plastic. By varying the rate of cooling, the solvents, and whatnot, they can control the tube size, wall thickness, and a lot of other stuff.
The result, plastic material that can be light and strong like balsa, insulate better than ceramic foam (like, a super-insulator), be flame retardant, and not rot when it gets wet. Or, they can go for more strength, bending or compressive, or... whatever you want.
Then, there's Quantum Radar to detect stealth aircraft. The biggest problem being the generation of large quantities of entangled pairs... then there was the other article I read (but can't find the link to) about generating pairs by the literal bucket-load.
Tonight, it was a cheap catalyst to make magnesite at room temperature, in days instead of hundreds of years. Magnesite sequesters CO2.
So, how about a thread on this stuff, and any follow-ups you hear about?
I remember reading about "the Internet," back when it was still a capital 'I' thing. One guy was saying it's going to be more important to humanity than the taming of fire. Hyperbole? Things are happening so fast now, that guy might have been right.
David...
David...
