Insert help needed for small boring bar
  • Insert help needed for small boring bar
    I got a good price on two baring bars but I am still figuring out inserts and would like to order the right ones the first time.
    The insert is diamond shape and very small. Under 3/8 x 1/4 (measure with ruler)
    The included wrench is marked with "T7" and "SFS"
    Two sites list this but they do not provide much information:
    http://www.guardiancatalog.com/Impor...p/01907815.htm
    https://www.mscdirect.com/product/de...907815?fa=true (not the right photo)
    Markings on the box:
    01907815
    S125/8"MSELPR05
    5/8" Steel SH 6"LG RH Boring Bar F/Blind holes
    Switzerland
    Markings on the bar:
    S125/8"M SELPR-05
    15-85846
    Can anyone tell me what insert(s) I need for this?
    01907815
    S125/8"MSELPR05
    Switzerland
    S125/8"M SELPR-05
    15-85846
    They were probably sold off cheaply because inserts are bit of exotic..
    Insert is Exxx-something (probably EPEX 1.51 or EPGT 1.51, can't say for sure if its not 2.51 size instead)
    Check the PDF below:
    https://www.kennametal.com/content/d...serts_inch.pdf
    1.51 size is 0402 in metric sooo these could be right:
    https://www.ebay.com/itm/STELLRAM-EP...EAAOSwxllbGZDM
      Thank you.
      I found this site and still looking for help.
      https://www.machiningcloud.com/wp-co...pplication.pdf
      The angle is more of a 55deg so I think its a "D"
      Clearance "P"
      Tolerance "E" or "G"
      Hole/Chip breaker Has a hole "T"
      Size ???? From center of the screw to the wall of the insert pocket is 3/16 which gives a diameter of 3/8 thus it is a "3"?
      Thickness ???? the pocket looks 2/16" deep or 4/32. It is less than the 1/4 so measured in /32 thus it is a "4" or is it a "2"? either?
      Radius ??? 0 is a point, 1 is 1/64 radius...5 is 5/64 radius I thinking a "2" or "3"
      The rest is really a big guessing game HC is coated,
      So I have a DPET 342?
      below is a DPGT 325
      Lower tolerance
      325 "2" Not as tall or measured using /16 meaning its right?
      325 "5" 5/64 radius
      the LF is light finish
      https://www.ebay.com/itm/KENNAMETAL-...IAAOSwgslbCLd0
        Still pretty sure its E-insert unless the markings are wrong on the boring bar!
        Second letter in boring bar type defines the insert shape SELPR
        A05H SELPR is even listed in the kennametal pdf I linked previously
          I'll post a pic when I get home.
          I agree with you but looking at the pocket, it looks to be 55 deg.
          Maybe that is why I got them cheap?
            Should be pretty easy to check the angle with angle gauge.
            55-degree D-insert would be about 100 times easier to source so that would be definite benefit.
              It is a 55-degree D-insert. So this is why MSC mostly discontinued these. For $30 for two? Not a bad price.
              I plan on order DPGT 325 to see if they'll fit.
              Thank you for the help!
