I notice on some emco v13,s on the tailstock side of the carriage there seem to be some wings attached. Does anyone know what these are for?
emco v13 question.
So it can fly through work?
If I'm thinking what you are... those are just a tail stock stop - to stop it sliding off the table.
Edit : Oh wait... I need to read "ON THE CARRIAGE".
See belowLast edited by lakeside53; 09-08-2018, 10:44 AM.
It makes a larger base for the carriage, so more sliding contact. Better stability and accuracy.The shortest distance between two points is a circle of infinite diameter.
Southwestern Ontario. Canada
Originally posted by jcfx View PostAll I see is tiny thumbnail too, but the spare parts manual for a v13 that those triangular things if that's what
you're referring to are called wiper sheets on the diagram.
They work also as leftover tool interference preventer. If you leave files or other tools to lay on the lathe ways between tailstock and carriage the wings lift your tools up so that you don't end up with two short files when you forget your file between tailstock and carriage
I always thought that they are there to guide the swarf away from way vipers? Maybe to stop tailstock smashing chips under carriage vipers?
Here is a better pic of them:
Originally posted by plunger View PostThats a much better picture. Thank you. Is that your lathe?What useful purpose can these have.?Location: Helsinki, Finland, Europe
