I wire the grinder up today and I am having a problem. (seems to be the norm for me) When I bought this it ran fine.
I called the seller and he says it is 220 3phase before someone asks.
It is acting like it is set up for 440 volts.
My rotary phase converter (5HP) works fine for my other 3HP surface grinder. When I hook up the new grinder the 3/4hp motor has no strength. It will spin up with the gear box set to 3100, 4000, and 5100 rpms. At 6500 it speeds up and gets about 50% and I assume the thermal protection pops and I lose power going to the motor. It cools down and I can try it again.
At 3100, 4000, and 5100 rpms I can stop it with my hand on the spindle. The belt is not slipping, I can hear the motor slowdown.
Spin down seems to be fast too but I don't feel anything binding.
What I've looked at:
Re-did all the new wiring. X2 time
Flip wires to reverse the direction.
Fliped it back and moved wires to cycle them??
Pulled the belt and the motor acts the same.
(also remove the mouse nest from the base. (all wires are in metal shielding)
Check voltage, the three legs give me 220 +- 15 (no load) and 110 +-10 to the ground.
I can't figure out could be causing this from the trip home on the trailer.
My questions:
Does anyone have a manual?
Is there anything I should start looking at?
Tonight I am going to open the wiring on the motor and check it. I will monitor this post if anyone has some thoughts?
Thanks for any help.
My questions:
