Spiral cutter sharpening advice using a T&C grinder
  • #16
    I have a 'Porta-Plane" with the factory sharpener attachment and manual in the shed, I'll try to dig it out and get some photos tomorrow.
    May help with alignment etc.
    It looks to have the same blade/cutter as depicted in the earlier pictures.
    Also, checked on line last year for new cutters, and they were still available then in both 'regular' and carbide versions.
    Edit:
    If I remember correctly, the shaft on the sharpener is threaded/twisted to match the helix on the cutter, but honestly, It's been at least 12 years since I even used the thing.
