I need to cut grooves down the center of this tube, ID is .5" Diam. Now the quick answer is "cut it like it is rifling" The quick answer is:
1. I don't have the equipment
2. it is wider then rifling would be so the load on the cutter might be to high to work, at least for anyway I can think of. Maybe OK for professional equipment which I don't have.
The twist is about 1 in 30, the groove is 0.050" wide and 0.008" deep. 4 grooves spaced equally around the bore.
I don't have any special equipment like a CNC shaper with a 4th axis rotary table etc. (don't laugh, that might actually work)
Any ideas?
Any ideas?
