Up lock valve on horizontal bandsaw saves blades and sanity
  • Up lock valve on horizontal bandsaw saves blades and sanity
    It takes two hands to raise my Kalamazoo, bandsaw one hand to raise it and the other hand to close the feed valve to make it stay up .If you are cutting thin stock and open the valve to quickly you will rip the teeth out of your blade My new combination valve is a handle to raise the saw and at the same time it closes off the return line and the saw stays up. After you advance your stock you just flip the red handle down and it starts cutting, retaining The feed rate that is set by the feed valve, in other words you never reset your feed valve unless you are changing to a different type of stock here are some pictures it was an easy conversionAnd saves A lot of aggravation Edwin Dirnbeck
    Great idea!
    That looks like one heck of a handle. Looks like two pieces joined with epoxy?
      Nice addition. My chinese band saw has already lock up valve but what I would really like to have also is a quick feed valve so when you are lowering the bandsaw closer to stock it wouldn't take half a year unless you fiddle with the feed rate.
        Great idea!
        It is a piece of waterpipe with a large steel ball silver soldered on the end.I just filled the pipe with RTV and jammed the valve handle in and let it harden.Edwin Dirnbeck
          The update was brilliant but a glued-together handle? Come-On! What's all that expensive shop equipment for?
            It had a weird shape ball end die cast handle once rtv hardened up it will last forever
              Combining the valve with the lift handle is pretty clever. One of those things that seems so obvious, but I never thought of it.
              Nice work!
