Dividing head project finished
  • Dividing head project finished
    Here are a couple of pics of my converted dividing head. I actually started this project with Sir John, but for obvious reasons that never worked out completely.
    So, I worked with a fellow here at work to do the programming of the Arduino.
    I have no immediate need for it, but have in the past so I thought i'd get it finished up. I'm looking forward to cutting some gears for something.
    Sid
    Very nice Sid,
    Did you make the bases and did you have drawings for the dividing head? Do you have any build photos you could share?
    Ron
      Originally posted by nc5a View Post
      Very nice Sid,
      Ron
      This is a conversion of an L-W dividing head. I just made the adapter for the stepper and mods to the input shaft. Not a from scratch build!
      Sid
        Very nice looking conversion. I've got a little dividing head like that. Hmmm.
          Well, I have the drawing for the adapter, should you need inspiration.
          Sid
            Pretty neat job. What is the accuracy of it??
            JL..................
              Nice work, as always.
                Sid
                I might take you up on that. As my now deceased mentor used to say, "It looks hell for stout."
                You mention Arduino programming. Did you go from the project in Village Press or did you roll your own?
                Jan
                  nicely done.....a very useful device.
                    +1. Everything this man makes is pretty.
                      Jan
                      The fellow I worked with started from scratch. I did point to some information in the Model Engine Makers forum. I think he may have gained some insight from there, but this is what he does.
                        As I said, I haven't cut any gears yet, so that much I don't know. However, I did do a rudimentary test by just using an angle block and an indicator. In that test, it was spot on.
                        What I'm more impressed with, is the B&S #9 .500 collet I bought from some supplier on amazon, had ~ .0005 run out!
                        I need to get a collection of collets now.
                        Sid
                          Thank you, both!!
                          Sid
                            Very nice job,I have a Tos Kurim Indexer that is designed to be gear driven from the Mill could it be powered similar to yours?
                              Way to go Sid! Looks good.
                              TTT - Do you have the table end mount and gears for it. That's so you can machine spirals. I'd like to have that universal DH but I can tell by the machine lift eye on top it's more than I can deal with right now. I can barely handle the new BS-1 dividing head I got before going into the hospital. It'll be a couple more months before I can even get it out of the drawer.
