Help identify this air grinder
  • Help identify this air grinder
    I would like to try to identify the grinder in the center of this picture it is a very handy grinder about 30,000 RPM takes 1/8 inch shank and shank is held with a set screw it is larger than a pencil grinder but smaller than common cutoff grinder it has a lot of power in a small space there are no markings on it only a sticker that is worn off thank you in advance Edwin Dirnbeck
