I have an el cheapo, very small analog unit that I use mainly to verify if there is power in a receptacle/switch/motor terminals/etc - or not.
While it works - afaik - no shocks yet - it is very old & I am considering something better. Mine is ill-suited to electronics; not that I am heavily involved but the current one is pretty much useless in this environment.
I found out about the category system - I thru IV - tho mine is unrated. As best I can determine a II or III would be quite adequate. I am more interested in the implied (?) protection that the ratings confer than the unknown of no rating at all? Or, is this confidence misplaced?
Are RMS readings essential? I know that a non-RMS meter is good only for sine waves. What would lacking this capability in an electronics environment - with square & sawtooth (among others) cause? Would readings be "slightly off" or too badly off-base to be relevant?
@ webmaster: Are brand names Ok? If not, please edit. I am aware of Fluke or Klein; are there other "knowns"? Other, "house brands" ( Cdn Tire, for eg) lack - afaik - any category ratings.
Otherwise, most seem to have a similar feature list; rms capability needs a higher-end device that would seriously raise the price - hence, my query about it as an essential or nice-to-have.
Price is a consideration: I would like to keep it under $100 (Cdn) but am prepared to go a bit higher for a more suitable unit (the rms thing again).
