Abom shows taking longitudinal measurements with rule and Mighty Mag as a stop
  • Abom shows taking longitudinal measurements with rule and Mighty Mag as a stop
    It's a 30 minute vid of vanilla lathe work (1100-pound workpiece). You can skip to 30:10 to see a still of the Mighty Mag technique - or skip to 17:40 to see video of same.
    https://www.youtube.com/watch?v=xXIvoGRHEoU
    Not bad but the workpiece has to be pretty big for that to be particularly useful. Could always just hold the rule to the part and do the same.
      With age may come the shakes ...
        I thought the method was a nice way to hold the rule while the other hands were moving the carriage. But perhaps instead of the cardboard ring or whatever it is a second Mighty Mag or other magnetic option at the other end too?
        Chilliwack BC, Canada
          I just watch all 3 parts (almost 2 hours) the card board ring is to keep the chips out of the steady rest's rollers.
            I didn't have that much patience. So I was skipping around even through the one video linked in the opening post. That's a heck of a good idea for chip control. Stuff like that shows he had a great teacher and has his own good head on his shoulders.
              A RANT,I also have done the scale balancing dance many times.
              I have ran large lathes like this for 60 plus years. It seems that old time lathe makers didn't realize that most lathe work has TWO DIMENTIONS,dIAMETERS AND LENGTH. The old lathes had incredible gear boxes and feed and threading mechanisms and real nice cross slide dials for establishing diameters. None that I ran had any provision for measureing LENGTH other than a crude micrometer stop designed by a beginer engineer.Very few of the tailstocks had an accurate dial for hole depth.As for as I know,there was never a USA lathe manufacturer that installed digital readouts at the factory,or even a travadial.. I know that the lathe manufactures must have used their own machines in their own plant.What were they thinking? .Oh well they are mostly out of business.rant over.Edwin Dirnbeck
                You do make a VERY good point Edwin. Many a time I've used calipers between a parting tool edge and the face of a part to get a decently accurate final length that is of a tighter tolerance then my Mk 1 eyeball can manage with a rule. Yet as you say there really is no good built in way to move a precise axial amount if it's longer than the travel of the compound rest.
                  DONT GET MME STARTED ON TRAVEL OF THE COMPOUND REST
                  To ad insult to injury,the STUPID MONARCH lathes that I ran, went to great expense and trouble so that the compound TRAVEL was one half of the dial readings. In other words the compound dial was graduated on DIAMETERS.These lathes were built with so much pride and skill and craftsmanship and sweat and blood by the workers in the plant. To bad designers didn't apply the same energy to using their brain more.Edwin Dirnbeck
                    Not to change directions..but in part 3, Abom machined 2" keyways in that shaft on a mill not much bigger than a standard Bridgeport! That shaft weighed 60-70% of the that mill.
                    https://www.youtube.com/watch?v=QZM04iCXuvo
                      Mag base, test indicator, and gauge blocks on the flat way for precise length movements.
                      But yeah, I agree, it should be built into the lathe itself. That's actually one of the only things I like about my Myford super 7 is the hand wheel on the end of the lead screw.
                      I enjoy watching some of Adam's videos. Always something to learn from them, and good production value.
                        A fair number of the smaller lathes from the Myfords and on down have that feature either directly or as an add on. My old Myford 7 (just 7) did not have the wheel but it was an optional extra. I was going to add a wheel but sold the lathe in favor of my 12x36 before I got "a round tuit". Such hand wheels are simply not spatially possible/practical for larger machines though for obvious reasons.
                        Some time back I bought a couple of those single axis DRO's labeled as being more for wood working tools than for metal working as they are only good to plus or minus a thou or two. I figured it would be good for the lathe carriage though as even with plus or minus a couple it would be great for a lot of things. We simply do not need to hold to a couple of tenths ALL the time after all...
                        But that's another add on solution. And the thread is all about the lack of such a feature from the factories.
                          Ahh, DRO's to the rescue. Abom79 is my favorite guy on Youtube, even donate to his patreon.
                            The Smart & Brown model A that I use at the museum has an adjustable scale on the main saddle wheel with 0.01" markings. I don't know what the movement is per turn, as I never use it. I really must remember to have a proper look at it.
