First results are in, and they are very positive. When the clutch is disengaged, there is absolutely no connection between the cone and the cup, and no drag at all. When the clutch is engaged, it locks up the cup and cone shafts. The pressure required to get the handle to "cam over" is quite small. I may rethink the adjustment I had modelled, because it looks like I can add one adjusting screw to the bar under the handle to limit how far it goes before it locks.
