China sent me an almost entire height gauge.
  • China sent me an almost entire height gauge.
    Any one have a spare scriber for a six inch?
    I should have known better.
    Make one, and make a YouTube video about making it.
      Been thinking about a large carbide tip lathe tool to grind down to fit.
      Or order a piece of oil hardening and grind to fit.
      Either way hand grinding to thou will be a challenge I would like to avoid.
        Is there no way to set the zero? Or could you get it down close to the final size then lap the face of the pointer?
        Plus keep in mind that you can set the gauge to 1" and use a 1" tall slug of brass with something like diamond lapping compound on the face that laps in the pointer.
          Sorry for my inexperience. What part of the gauge is that? The sliding part?
          If so I just need the dimensions. I turned some gauges into my supply of straight edges and I am sure I did not get rid of the sliding mechanism (or the bases).
          I need the ID of the rectangle. If I have it, it is yours. JR
            If I remember correctly, you don't need to grind to a thou. The height is reset each time you use it.
            I could, of course be wrong.
              It may not be a matter of the measuring edge position (if the the zero is re-settable) , but rather making the bottom of the scriber flat and perpendicular to the beam/parallel to the base if it will be used for height measurements.
              You can buy a scriber quite inexpensively. Even Starrett sells a new one for $27 (http://www.starrett.com/metrology/pr...detail/PT22357), so eBay finds or brands other than Starrett should be less than that.
                That is inexpensive for that brand. I dont get the need for carbide, for spindle tips of a mic yeah. Over kill for a transfer gauge. JR
                  There's a fair chance that the seller will send you the scribe if you let him know.
                    I would second contacting seller - import company swapped out the inserts on a boring bar for me to Acme willingly. I just had to ask.
                      Just to make the edge stand up, as it is used to scribe lines. once made/bought, they can be sharpened. The parallel/perpendicular deal is important if you are picking up heights, so it does not matter exactly what part touches.
                      They are considered a consumable part.
                        Easy-peasy.
                        Step 1: buy a surface grinder
                        I always consider it a victory if I can wrangle a new machine tool purchase, rather then paying $27 for a completed product...
                          Amazon has a bunch of different size height gauge scribers: https://www.amazon.com/s/ref=a9_sc_1...qid=1540053726
                          RWO
                            Originally posted by tmarks11 View Post
                            Easy-peasy.
                            Step 2: While at the dealer, get a wire EDM to slice carbide.
                            After all, we need to find a way to spent money saved by buying a Chinese height gage.
                              Well, raise holy hell with the seller. If E-bay or Amazon, CC them too. If a US importer, like Grizzly, a phone call will probably resolve the problem.
                              Make it fit.
