Rotary table id help please
  • Rotary table id help please
    I picked up this 8" rotary table yesterday for $45.00. It's in very good shape BUT I may have purchased an Asian unit thinking it was usa. I don't see any manufacturer information anywhere on it. It does have two letters cast into the base and a few numbers cast into one of the slides. The quality of the bits and pieces seems far better than most chinesium that I have seen in the past. The screws that retain the gobs as well as a few other screws are USA thread so I have that going for me which is nice [emoji16].
    There is a decal above one handle that is barely perceptible. It looks like it may have been a red oval decal (Craftsman?). Any help with knowing what I have is greatly appreciated.
    Fwiw, if this buy tanks at least I got a nice 1" digital micrometer for $8.00-Mitutoyo too.
    Sent from my Pixel 2 using Tapatalk
    Can't help with the brand, but the dials do look a lot like Craftsman. For an 8" RT those slides look awfully slender. Overall the stiffness of that assembly would likely preclude any heavy slotting or profiling. Might be fine for bolt-circles, aluminum work etc.
    Southwest Utah
      It sure looks like you might have a Palmgren RT with cross slide table for drilling. https://www.youtube.com/watch?v=jpj2KAD1wH0
      But from the underside the base really looks like this Craftsman model. All the details seem to match. http://craftsmanpowertools.top/vinta...tary_table.php
      Dan
        Craftsman or Palmgren most likely. Craftsman at least was at one time the same as a Palmgren model, but later may have been made cheaper.
          Probably a Palmgren made for Craftsman. The Palmgrens have the rotary part on the top, the good ones have the rotary part on the bottom, which is much more useful.
            Yup, that's it. Seems like a decent purchase anyway.
            Thanks
              Yes on Craftsman/Palmgren. In the first photo it is shown inverted.
                I thought I had seen a picture of a Palmgren with the table on the bottom, but perhaps that was made by someone else. Looking at it upside down like that makes me wonder if a T-slotted plate could be fixed to the inverted unit, after the base had been cleaned up a bit better of course.
                  Huh? The rotary table has T slots in it already so?
                    Not on the underside.
                      Since no one had mentioned your $8 Mitytoyo.... YOU SUCK!
                      Both are nice purchases.
                      Dan
