Title says most of it, can anybody recommend a good grinding wheel for cast iron, or at least point me in the direction of what i should be looking for?
Intended application is use on a surface grinder, for grinding some durabar i have lying around. Ive tried making heads or tails of this stuff, but between all the numbers and letters ive just ended up very confused. At the moment ive got one of those ruby grain wheels in 46 grit and a H hardness, picked because id heard that its a good 'meh, throw whatever at it" kind of wheel. From what ive gathered though, cast iron and other non-ferrous's prefer silicon carbide wheels, and softer materials like harder wheels? That in mind, grinding cast iron would be done with something like a 46 grit silicon carbide wheel in maybe a J hardness?
Like i said, im hoping someone smarter than me can point me in the right direction here. Somewhat tangentially related, does anybody have a source for those precision ground flat stones i hear so much about? Nearly every video i can find about using a surface grinder mentions using the stones to deburr parts and the mag chuck before use, but none of them ever mention a source. Only one ive found is wanting $500 for a set, at that price im thinking it makes more sense to get a diamond wheel and make my own, which im not opposed to, but if i can find the stones at a better price than the wheel, just makes more sense going that route
