Supreme reversable tapping head model 00 collets needed
  • Supreme reversable tapping head model 00 collets needed
    I just bought a supreme reversible tapping head model 00. It only came with one 3/8 collet. I'm in search of a set of collets for it if anybody has any that they wish to get rid of please pm me.
    Also, I'm doughtfull but hopefull that someone here will have any . Anyway does anybody here know what kind of collets this tapper uses?
    Here is a video of it in operation
    https://goo.gl/images/dTFJgR
    https://youtu.be/OoCwplJuU_8
    My set has 5 collets, none are 3/8". Mine is a supreme 00 model 9000. The model 00 is cast on the bottom and the 9000 appears on the top label. It has #6, #8, #10, 1/4 and 5/16" collets. Taper is on the top of the collet. Bottom of the collet is split to fit over an internal pin to prevent collet slip. Also has 2 drive adapters, 1/4" shaft and a 3/8-24 internal thread. Collets are marked 9000-6, 9001-8, 9002-10, 9003-1/4 and 9004-5/16 so when you find them you can be sure they will fit.
      I pretty much think Ricky nailed it.
      Is the sepreame silver in color and come in a sturdy metal case? I might have one. If I have two of what you need one is yours. JR
        Ok thanks guys. It's in shipping right now and I'll be away for a few days. As soon as I receive it I will reply. The description said it only included one collet, 3/8. From what the internet has revealed is that Ricky is correct .
          JRouche. This is what I have: supreme model 00, a 1/4 drive adapter, a 5/16 collet and the knurled collet nut.
          What I need is : #6, #8, #10, 1/4 collets and one drive adapter 3/8-24 internal thread. The box is also missing.
          If you have any of the items listed above please PM me and we'll work something out.
          Thanks much
            Hi,
            I have owned one for years. I have broken a collet or two over those years. They aren't particularly hard to make from round stock. Even mild steel will make an OK collet for light home use.
