Thanks for all the replies. Couple of things- as I mentioned I'll often take a file to the surface I've just machined to knock down the high spots. I do this under power so the entire surface gets 'treated' equally. Sometimes I go for a dull file so I'm not really taking material off, and sometimes I'll reverse the spindle to apply the treatment from both directions. I don't know if this is beneficial or not, but I do it anyway. Using a file I'm typically taking off about 2 tenths, so about 1/2 thou overall from the diameter. I factor this in when I'm turning to allow for this 'shrinkage'. I would imagine that burnishing would require about the same allowance- and I wasn't expecting to be able to shrink a diameter by two thou, more like 1/2 thou perhaps. Just enough to turn a too-tight press fit into a useless sloppy fit, if you know what I mean
No, I've never done that before, nope-
By the way, I've tried over the years to get a good feel for how much extra to leave on a work piece so that my file method would bring it to the exact desired size. Now I pretty much always use the file before the caliper or micrometer measurement is made. I think I do pretty much get a more consistent reading this way as well.
As far as burnishing, I might just make up a dual ball bearing setup where I can adjust the spacing between them for whatever diameter I'm working with at the time. I'd probably set the gap slightly small- then I could hand-hold this tool over the workpiece and let it do its thing. If the gap is too small I won't get enough pressure between the rollers, and if too large it will just pass right over without doing anything. There will probably be a 'sweet spot' where I'll get lots of pressure between the rollers without having to apply too much side pressure against the work piece. Using ball bearings as rollers is probably not the best, but it should be somewhat effective anyway. Maybe I could find some roller bearings that would be more suitable- perhaps I could cannibalize some roller lifters to make this tool.
Or- maybe I could use smooth rollers in a knurling tool-
