I have several of the Village Press hard cover books from HSM and PIM, and in browsing through the Projects Three book came across an article by Edward G. Hoffman "Wiggler Bar and Test Bar."
Confusion sometimes comes easy when dealing with left vs right, in vs out, etc. So I'm wondering if my mind is tricking me here.
In describing the test bar, Edward says "...take a 10 to 12" bar .875 to 1.00 dia., center drill both ends, mount between centers, take a light skimming cut until it's cleaned up all around. Then measure at both ends. If larger at tailstock end, the tailstock should be moved AWAY from you. If larger at headstock end, the tailstock should be moved TOWARD you."
That seems bass ackwards to me! Did Edward make a mistake? Or is Lynn making one now?
