Setting the tailstock set-over just right
is just a standard part of setup when
the tolerance of the job calls for a job
that has to be really straight, without
any taper. Usually the tailstock set-over
is adjusted with the actual workpiece
set up in the lathe, in context.
In the grinding world, the table is always
adjusted for set whenever the tailstock
is moved. Parts can be changed between
centers, but if you move the tailstock,
you must re-adjust the table set.
With a lathe, it is tolerance dependent
to tweak tailstock set-over or not.
Using a tramming bar thingy and hoping
to set it and forget it, is a false dream
of running a lathe.
--Doozer
of running a lathe.
--Doozer
