It’s so easy, get a bigger scrap bin, usually works, I am joking btw, some of the most difficult things to machine look easy at first glance, inspecting them is even harder as bugger all is nailed down and measurements are hanging in space at intersecting planes, I had a gearbox casing similar to that ok 2’ tall, the drawing looked easy till you discovered you couldn’t inspect it due to the intersection of 2 inclined planes, you can’t measure the corner, well not accurately, piss around with a clock etc.
The solution was a tooling ball set in the plane that measurements could relate to.
Mark
Mark
